Can you supply more details such as how are they not working. Are the showing in your MyBT. What happens when you try to activate them etc etc.
Hi ,
It looks as activated, however when I make a test, all the web content is visible . I have tried to restart the modem but didn't make a change.
You may already have done this but if not check through these links and sub-links to see if you may have missed something.
Hi,
I have tested parental control on my ipad and iphone using BT wifi . They working fine as expected. It was not allowed to enter to any adult sites
But the Macbook air doesn't recognize any parental control . It is allowing to access to all adult content. What could be the reason? Why is it bypassing it?
Kind Regards
Do you have a VPN set up on your Macbook?
Hi,
To be honest, I don't know. How can I check that?
Is your Mac a company owned device, if so it will most likely have a VPN set up.
If not you would have to have set it up to use a VPN. See link how to check the settings to see if one is being used.
https://www.howtogeek.com/216209/how-to-connect-your-mac-to-any-vpn-and-automatically-reconnect/
