Mars2003
Message 1 of 5
Parental Controls
Flipping parental controls are blocking 9gag.com
I've never set up any controls in the past, what's going on?
4 REPLIES 4
RobbieMac
Moderator
Moderator
Message 2 of 5
Re: Parental Controls
Hi Mars2003,
There was an issue with parental controls a few days ago, sorry for the problems you were having.
It should be sorted now, can you access that site again?
Robbie
Mars2003
Message 3 of 5
Nope, still being blocked.
Costaz
Message 4 of 5
I have the same problem - cannot connect to https://www.thewinesociety.com, unbelievable! I did not activate or request Parental Controls, when I try to override it says I'm not the account holder (though i can connect to myBT). I activated and deleted, no luck yet..
Mars2003
Message 5 of 5
Seems to be rectified now.
