SuiSydul
Message 1 of 2
Parental control blocking reddit apps
Hello,
Parental control seems to block reddit apps on Android. I have the parental control on the light setting and reddit via the Web works but through the apps, they're blocked. Anyone know why? And how do I fix this? Through the app nothing loads until an error message comes up. Only way to fix it is to turn parental control off, which I don't want to do.
(apps work when using mobile data)
Tags (1)
1 REPLY 1
DavidM
Moderator
Moderator
Message 2 of 2
Re: Parental control blocking reddit apps
Hi SuiSydul,
Welcome and thanks for posting. Can you try adding reddit.com to the “allowed list”. Instructions how to do this can be found here:
http://bt.custhelp.com/app/answers/detail/a_id/46768#allowingsites
Let us know if that helps.
Cheers
David
