Message 1 of 4
Parental controls on but switched off
I have all controls turned OFF but I keep getting channels asking for a PIN number due to parental control - what's going on ??
3 REPLIES 3
Message 2 of 4
Re: Parental controls on but switched off
That is the subscription channel  providing rated content  pre watershed. Discussed in many threads already.
Message 3 of 4
I did try and find an answer but couldn't -
Can you point me to the thread that sorts this out ?
Message 4 of 4
If a Mandatory PIN is required then you must enter the PIN to view.
It is a safeguard that the Channel  Provider has introduced to enable them to conform to OFCOM  guidelines on rated content pre watershed.
