Message 1 of 5
Passwords
I want to change my email password.
Can I just change my bt.com password or are they different?
Thanks.
T
4 REPLIES 4
Message 2 of 5
Re: Passwords
Hi @Thompson218 and thanks for posting.
The BTiD and email passwords are independent but you can use the same one for both. Does I need to change or reset my BT Email password help?
Cheers
David
Message 3 of 5
Re: Passwords
Thanks David, I use a password manager and would like to use different passwords. Are these the areas that I need to change or are others?
bt.com
Email
Billing
Ta.
Message 4 of 5
Re: Passwords
Hi @Thompson218,
Thanks for the reply. You would only need 2 passwords. One for your email and one for your BTiD (where you can view bills etc).
Cheers
David
Message 5 of 5
Re: Passwords
Ok, thanks.
