Bt offers broadband speeds up to 72mb/s , which is pretty deascent , for average home use.
But when looking at other ISP's i see WAY better offers.
Like eir , they offer 1000mb/s , which is 928mb/s faster than BT's fastest.
So why are BT holding back?
The reason this came to my attention is that my BT broadband had a down speed of no less than 50mb/s ever , yet the past week it has for some reason been at a ateady 15mb/s.
And my upload use to reach 10mb/s , and now sits on 8.5mb/s.
and even though the speeds i origionally had (which have for some reason disappeared) are better than what they have reduced to , they are still no where near the standard of eir's 1000mb/s.
BT why wont you do anything to improve speeds.
Welcome to this forum.
This is a customer to customer forum only,
This is where customers help each other get the most out of BT products & services.
Anything you post here does not go to BT. Although the forum is moderated by BT, not all posts are read.
Everyone posting here, are just BT customers like myself
This is a public forum which can be viewed worldwide, so please do not post any personal information, especially phone numbers, account numbers, fault numbers, address information or email addresses, as this could be used to impersonate you.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Then, if you have a Home Hub 5, please display the full connection statistics including noise margins, by following the instructions on this page.
Check your connection speed for the Home Hub 5
Could you please post the results from the BT Speedtester, including the further diagnostics.
BT Wholesale Speedtester
i dont have hub 5 , i have hub 3 , and i understand its not going to have great up and download speed , considering its 2 generations behind , my issue is 1. why did it suddenly drop in speed and 2. why would someone upgrade to a plan for a max of 72mb/s , when there are others with 1000mb/s
So you must have a white Openreach modem?
Its that which determines the connection speed, not the home hub 3.
yes i do have one , is there any way to fix the issue , or any site that will give me a rundown?
unfortunately all the useful stats are held by the modem unless you have it unlocked. post results from dslchecker and btspeedtester diagnostic test - Keith provided the links
can premesis be used for personal home use?
premises as in business premises should be using a business conenction according to BT T&C residential lines should not be used for bsuiness purposes or do you mean FTTH - fibre to the home? dslchecker will show if available
