dcorbet
Message 1 of 10
Pay to replace a faulty extension socket?
Our BT extension socket seems is faulty and BT says I have 2 options:
1. Buy a replacement
2. Get a BT engineer to fix it for £99
My question is: as it is BT equipment and it was installed by BT, why should I have to pay for it's replacement if it's faulty? I can hardly hear anyone at the other end of the line (including the BT customer service people) - and yet it's my problem? I don't get it.
9 REPLIES 9
john46
Message 2 of 10
Re: Pay to replace a faulty extension socket?
all extensions after the master socket are the customers responsibility not that of Openreach
dcorbet
Message 3 of 10
Um, that doesn't really help. The socket is from open reach and was installed by them, so why is it my responsibility?
john46
Message 4 of 10
once installed there responsibility ends Openreach are responsible for the connection up to and including the Master socket only as an extension can be installed by your self or a competent electrician
dcorbet
Message 5 of 10
I'm not talking about an extension - I'm talking about the box on the wall that Openreach installed and that the phone line and modem plug into. I don't understand why that's my responsibility if it's faulty. I didn't install it.
john46
Message 6 of 10
"Our BT extension socket seems is faulty and BT says I have 2 options:"
if you have no extensions you are refering to the Master Socket you are only responsible if the socket  shows signs of damage  or internal moisture
the charge you have been told of is a warning you may be charged  if it is damaged  any other fault is free of charge
dcorbet
Message 7 of 10
Ok - thanks for clarifying. It's faulty as the phone line is terribly crackly. I've already spoken to the help desk and they told me to remove the front plate and plug the phone into the test socket and it worked fine. When I put the plate back in the front and plugged the phone and modem back in, the problem resumed. I have booked an engineer for Friday. Thanks for your quick response to my query.
john46
Message 8 of 10
Any time 😉
Reed_Richards
Message 9 of 10
So do you use any extension sockets or just the Master Socket.  If you just use the Master Socket then you can leave the faceplate off and save yourself £99.  Or removing the wires attached to the faceplate would probably do the trick.  But either would cut-off any other telephone outlets you have.
These days many of us use cordless phones that only require one phone socket to support several phones.  So telephone extensions around the house are not the boon that they used to be.
Devon_Dave
Distinguished Guru
Message 10 of 10
As long as you are aware that you will probaly be charged for the visit?
Openreach would more than likely just disconnect any faulty wiring on the rear of your front plat of your master socket, they would not normally replace anything.
As mentioned do you need the extension sockets?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
