Message 11 of 39
Re: Peak time connection issues. Not the usual.
Hi I suggest you contact the forum mods now you have definitely exchange problems they can this sorted for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
BLACKW47CH
Message 12 of 39
How long do they take to reply? Not even had a conformation email yet.
Message 13 of 39
as it says in the post  up to 3 working days  there should have been a ref number when you submitted the email
BLACKW47CH
Message 14 of 39
I got an email today saying my issue should have been resolved. Well it hasn't. Speed test a moment ago showed 0.49 mbps
I've seen other people here posting this info.
Can you tell anything by this:
ADSL Line Status Connection information
Line state: Connected
Connection time: 4 days, 16:56:35
Downstream: 7,968 Kbps
Upstream: 448 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1
Annex A Latency type: Fast
Noise margin (Down/Up): 8.1 dB / 27.0 dB
Line attenuation (Down/Up): 28.5 dB / 17.0 dB
Output power (Down/Up): 20.1 dBm / 11.9 dBm
FEC Events (Down/Up): 0 / 2
CRC Events (Down/Up): 2796 / 18
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0 HEC Errors (Down/Up): 11277 / 11
Error Seconds (Local/Remote): 0 / 0
Message 15 of 39
your connection looks ok - need btspeedtester results please
BLACKW47CH
Message 16 of 39
I'd love to but over the last week, having tried to use the "Tap3 Test Configuration" of the speedtest around 30 times different times of the day, it has worked exactly 0 times, and always fails at 96%.
Message 17 of 39
the tap 3 test is not needed
Message 18 of 39
even the beta version would be better than nothing
BLACKW47CH
Message 19 of 39
Here are the Beta results:
Ping Latecy (ms): 208.22
Download Speed (Mbps): 0.30
Upload Speed (Mbps): 0.33
Thanks.
Message 20 of 39
reply to them saying your speeds are still to slow
