208197511001B
Message 1 of 4
Performance Tuning
Hi
Now that I have been taken to Infinity, I have started to think about performance.
The Home office is going to get a make over in the new year.
Got me thinking about cable routing, power and Hub positioning.
Hub
As supplied comes with a cheap cat 5 cable to connect to the Modem.
Is it worth buying a top quality cat 6 cable and replace the cat 5?
Is it worth making this cable as short as possible?
Is it worth fixing modem to the wall next to master socket and running patch cable to Hub up on the desk. (Seperate hub from Modem)
I have the modem and Hub on a power surge protected distribution board. Is it worth running the modem cable (cat5/6) through this board to the Hub? Or just leave the power protected.
Hub Location
Got it well away from power supplies and a radiator. But it's near a monitor.
Does height off the floor make any difference. I need the wireless to work well downstairs not in the room it's in.
I also discovered when you power up you should power modem first and wait for DSl light to go green then power up Hub.
3 REPLIES 3
Bullitt
Distinguished Expert
Message 2 of 4
Re: Performance Tuning
the most important is the modem and its connection to the phone line
you want it away from any electromagnetic interference and the rj11 lead to the phone socket should be twisted pair
sjtp
Guru
Message 3 of 4
As Bullitt says, the modem/master socket connection is the most critical.
Hub
Doesn't make too much difference.  The modem LAN port is only 100Mbps ethernet.  You are unlikely to see any loss even with 30meters of cable, and as long as the cable isn't terrible, cat5 cable should be fine.
I don't know.
Hub Location
I don't think it will matter too much being near a monitor.   Generally higher up is better for good wireless reach.
Install inSSIDer (free) on a laptop and experiment with different positions of the HomeHub to see your best compromise between convenient position of HomeHub and good wireless coverage.
I don't think it matters too much.  On the very rare occasions I have rebooted my modem I have left the HomeHub on.  And when they both went out after a power trip, they came up together with no issue.
pippincp
Sage
Message 4 of 4
Even CAT5 cable is good for up to 100mts with no loss in data transfer.
