shirley_connon
Message 1 of 12
Performance issues - SNR Margin range Downstream (DB) 3.0 to -0.2 since 14th May
Hello,
Experiencing regular disconnections (every 2 days or less) / stability issues from internet and slow page loading since 14th May.
SNR Margin downstream and upstream is normally in range of day = 6.5 and night = 5.5 (DB) for last 6 months which is relatively stable.
Now getting regular SNR of 3.0 downstream (day and night) and has dropped to 0 at times at evening. SNR at 3 seems to generate lots of HEC errors, slow page loading and issues using VOIP although connection rate seems higher.
Seems to be connecting at SNR of 3 for a few days then drops back to 6 SNR again after an disconnect and then repeats again after a few days. Not sure if something is triggering to lower the SNR to 3 thinking it is stable then realising unstable so re-adjusts back to SNR of 6.
Modem (Billion) connected to master socket (Openreach MK3)
Quiet line test no noise even when SNR at 0
Resetting modem does not help
Connecting to test socket does not improve SNR
Connecting alternative modem HH4 same SNR
Replaced router cable
What i see when connection drops. I can watch the SNR reduce step by step down to 1 or even zero over a 5 or 6 minute period at nights. After a few minutes goes back up to SNR of 3 which is still generally unstable with slow connections to web pages and issues using VOIP for home working etc. Did previously see drops to 3 at night occasionaly when the default SNR was 6 but at 6 as a starting point there seemed enough headroom to keep connection.
Connection information 31st May
Model Name
BiPAC 8800NL
Host Name
home.gateway
System Up-Time
12D 17H 30M 35S
Date/Time
Tue May 31 15:56:09 2016
Software Version
2.32d.dh65
LAN IPv4 Address
XXXXXXXXXXXXX
LAN IPv6 Address
XXXXXXXXXXXXX
MAC Address
XXXXXXXXXXXXX
DSL PHY and Driver Version
A2pv6F039g1.d24m
Wireless Driver Version
6.30.102.7.cpe4.12L08.4
WAN
Line Rate - Upstream (Kbps)
961
Line Rate - Downstream (Kbps)
4348
Default Gateway / IPv4 Address
pppoa0 (DSL) / XXXXXXXXXXXXX
Connection Time
2 Day(s) 13:38:26
Primary DNS Server
213.120.234.70
Secondary DNS Server
213.120.234.50
Default IPv6 Gateway / IPv6 Address
pppoa0 (DSL)
xDSL
Mode
ADSL_2
Traffic Type
ATM
Status
Up
Link Power State
L0
Downstream
Upstream
Line Coding (Trellis)
On
On
SNR Margin (dB)
3.3
5.8
Attenuation (dB)
52.5
33.7
Output Power (dBm)
0.0
12.7
Attainable Rate (Kbps)
4808
968
Rate (Kbps)
4348
961
K (number of bytes in DMT frame)
0
0
R (number of check bytes in RS code word)
0
0
S (RS code word size in DMT frame)
0
0
D (interleaver depth)
32
4
Delay (msec)
8
6
INP (DMT symbol)
1.00
0.50
Super Frames
68122430
60833959
Super Frame Errors
209469
1621
RS Words
1600684123
1257012
RS Correctable Errors
25969919
11193
RS Uncorrectable Errors
8808407
0
HEC Errors
7849955
2225
OCD Errors
1286
0
LCD Errors
1286
0
Total Cells
4016658719
882218646
Data Cells
177734324
41552369
Bit Errors
467714984
72026
Total ES
14971
985
Total SES
3184
0
Total UAS
3479
387
Recent connection information on drop. Note SNR -2
xDSL
Mode
ADSL_2
Traffic Type
ATM
Status
Up
Link Power State
L0
Downstream
Upstream
On
On
SNR Margin (dB)
-0.2
6.1
Attenuation (dB)
52.5
33.6
Output Power (dBm)
0.0
12.6
4236
988
Rate (Kbps)
4438
964
0
0
0
0
0
0
32
4
Delay (msec)
8
6
INP (DMT symbol)
1.00
0.00
Super Frames
2554424
2306513
Super Frame Errors
21770
70
RS Words
23794089
3989406
703515
138
685317
0
HEC Errors
593296
139
OCD Errors
145
0
LCD Errors
145
0
Total Cells
61934672
13146621
Data Cells
26272362
1122932
Bit Errors
33316580
4589
Total ES
6531
35
Total SES
216
0
Total UAS
326
113
Any advice
Jon and Shirley
11 REPLIES 11
imjolly
Message 2 of 12
Re: Performance issues - SNR Margin range Downstream (DB) 3.0 to -0.2 since 14th May
can you check for interference that may be causing the drop in noise margin
interference causes
do you use a phone extension cable to connect hub to MK3
shirley_connon
Message 3 of 12
Hello,
Thank you for the response and advice.
The house is basically in shutdown mode during the day apart from my office room which has a monitor and laptop eg not heating, pumps etc Tried disconnecting a dect phone, sky box and any other electrical items for 5 hours this evening but SNR is still showing at around 2.8. No new electical items have been introduced since issues started on the 14th May.
I use a RJ11 cable to connect from the hub directly to the data port on the Openreach V3 socket.
The cable has been swapped out and also direct connecton using a filter to master socket also tried.
I have a fairly long line straight to the exchange rather than a cabinet hence SNR of 3 is pretty unstable which it seems of to defaulted to most of the time. A SNR of 6db seems to be required to keep the connection stable in my case. Not sure if something has changed at the exchange side to set SNR to 3 as default.
shirley_connon
Message 4 of 12
Hello,
I believe DLM can reduce noise margin to 3Db.
It looks to me that the DLM has reduced my line to a 3Db profile which although gives a faster connection speed is generally more unstable on my direct long copper line to the exchange.
Over the last few weeks my current downstream SNR is basically 3DB lower than usual taking into account my usual 1-1.5 db variences between night and day.
Can a 6dB profile be set on my line with interleaving still left switched on to help stabalise this ?
Of course you are the experts so just adding my thoughts and observations 🙂
Many Thanks
Jon and Shirley
imjolly
Message 5 of 12
the DLM reduces the noise margin to 3db on what it considers good connections but on a few occasions the new normal noise margin can cause problems  I still think there is interference causing your noise margin to drop to zero but see if mods can reset your noisemargin back to 6db and stabilise your line  mods will post a contact us link here
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 1/2 working days either by phone or email
shirley_connon
Message 6 of 12
Thank you very much for your help.
I will continue to explore potential interference areas and await contact from the mods to see if they can reset my noisemargin back to 6db and stabilise the line.
Jon and Shirley
DavidM
Moderator
Moderator
Message 7 of 12
Hi @shirley_connon and thanks for posting.
I'm sure we can help you with this. Can you drop me over an email with your details? You'll get the contact the modeators link in my profile.
Cheers
David
shirley_connon
Message 8 of 12
Hello,
After some changes bny Rowan it seemed the SNR margin became stable at 6db for a while.
However this has now reverted back to a 3db SNR profile again.
Rowan advised that if this solution implemented did not work then a fixed 6db Noise profile would need to be set/requested to Open Reach.
Rowan advised to raise the issue back again through the forum if it reoccured
Can you advise the process to reopen or do I need to open another call ?
xDSL
Mode
ADSL_2
Traffic Type
ATM
Status
Up
Link Power State
L0
Downstream
Upstream
On
On
SNR Margin (dB)
3.4
4.8
Attenuation (dB)
52.5
33.9
Output Power (dBm)
0.0
12.7
4848
940
Rate (Kbps)
4352
924
imjolly
Message 9 of 12
mods will post here
RobbieMac
Moderator
Moderator
Message 10 of 12
Hi @shirley_connon
I've let Ronan know that the SNR has dropped and it's causing stability issues again.  He'll be in touch to let you know what happens next to get it back to 6db and stay there!
Cheers,
Robbie
