I get really frustrated when I move from one room to another in my home, but instead of connecting directly to my Homehub, the phone connects to BTWifi-with-FON. I have read on here that I should simply go into my wireless settings and click on forget network.....yes, this does work, but why should I have to do it....there is no problem with signal strength from the hub, I can be less than 5 metres from it in the same room, and it connects to FON.
Solved! Go to Solution.
Hi @pangit,
Take a look at Why do my devices keep connecting to BT Wi-fi instead of my BT Hub?
PaddyB
