Message 1 of 2
Phone line not working
For some reason my landline has stopped working... The phones are fine and working perfect as checked this. My Internet is also working... Any suggestions as engineer wanting £130!! If there's a fault
1 REPLY 1
Message 2 of 2
Re: Phone line not working
The £130 is only if the fault is proved onto your own equipment or wiring past the main socket. You could also be charged if you have damaged the line in your property.
Have you tried a known working corded phone into the test point of your main socket?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
