Supernova
Message 1 of 8
Phone number supposedly ported but previous provider says not...?
Hi,
Hoping someone can point me in the right direction here please.
Moved to BT last week, and until yesterday afternoon I was unable to receive calls on my landline.
I knew this was a number port issue, which after several long and pointless phone calls to Support I unfortunately ended up threatening not to pay them unless they fixed this in 24 hours.
Thankfully that seemed to get my point across, and I received a call back saying that they had done the port. Sure enough, a call to 17070 and a line test proved this, as well as some test calls from other landlines and mobiles. I thought all was sorted, until I called Virgin Media to ensire the old contract was cancelled.
However, to my surprise Virgin still advised that the number hadn't been ported! They advised I needed to speak with BT again to port the number, however I don't understand how that can be if everything appears to be working. I can only think that it's one of two things - either it just takes time (24 /48 hours etc) to update on Virgin's system, or if I force Virgin to cancel the service it with stop my phone working again as Openreach have done some funky routing with my number.
Hopefully someone with a better understanding of these workings can advise please? 8 days into the contract and I'm already regretting moving to BT!
7 REPLIES 7
PaddyB
Moderator
Moderator
Message 2 of 8
Re: Phone number supposedly ported but previous provider says not...?
Hi @Supernova,
Welcome to the community forum. I'm sorry to hear that your number hasn't been ported across correctly. I'll be able to take a look at this for you.
Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Supernova
Message 3 of 8
Thanks PaddyB.
Details sent.
Supernova
Message 4 of 8
Hi PaddyB,
So, long story short, I spoke to Virgin however they advised that they still have not received a porting request from BT.
But as the phone line is still working I told them to just cancel the line.
Guess we shall see what happens!
Thanks for your help PaddyB.
NeilO
Moderator
Moderator
Message 5 of 8
@Supernova Thanks for posting and letting us know. Did they advise you when the cancellation would complete on their systems?
Supernova
Message 6 of 8
@NeilO The account has actaully closed already, and the line still seems to be working.
Checking here though www_textmagic_com/free-tools/carrier-lookup still shows the carrier as Virgin Media though, as do similiar services.
NeilO
Moderator
Moderator
Message 7 of 8
@Supernova it's definitely on the BT network according to all the checks I have made and this has also been confirmed by the Openreach number port department.  Those third party checkers will likely take a while to reflect the transfer.
Supernova
Message 8 of 8
@NeilO That's good to know, thanks.
Just wonder why it wasnt showing correctly on Virgin's system? I would have thought that they would know the number has been ported. But that's not your problem 🙂
