Just had a phonecall on my landline claiming that my ip address has been compromised in a foreign country and advising to select 1 to go through to the BT Technical department - was this a scam ?
@Darraswrote:Just had a phonecall on my landline claiming that my ip address has been compromised in a foreign country and advising to select 1 to go through to the BT Technical department - was this a scam ?
Hi, welcome to the forums.
100% scam.
There are many similar posts in these forums.
Yes. To save repeating everything here have a look through the forum and you will find hundreds of similar posts.
Thanks both, always worth checking.
