Caerphilly
Message 1 of 2
Physical Connections: Home PC & Xbox 360
Hi,
I have 2 Physical Connections showing in BT Home Hub/ Settings/Advanced settings/Home network.
- Home PC:- Currently Connected
- Xbox 360:- Currently Connected
Q. I have experienced lots on lag issues on Xbox live and wondering if disconnecting the 'Home PC' Physical Connection when playing on Xbox Live would make a difference towards the 'Xbox 360' Physical Connection.
1 REPLY 1
NilSatisOptimum
Recognised Expert
Message 2 of 2
Re: Physical Connections: Home PC & Xbox 360
You should be ok depending on your line stats, also what the Pc is doing when on the xbox!.  Live was having server issues last night, for me anyway.  If you could post your stats from router and run a Bt speed test to see if all is alright.
Also consider what games you are playing, if its Activision or Ea game, then thats the nature of their poor servers.
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
