Message 1 of 10
Ping spikes
Hello,
I'm fairly new to BT and my connection has been pretty good so far.  But recently, I'm experiencing ping spikes in my games that I play - it usually goes from 20-30 to 100 for a good 4-5 seconds, then back down to 30-50, then up to 100-150.  It did this for a good 5-10 minutes earlier and then stopped.  My friends weren't having any of the ping spike issues, so I assume it's something to do with my connection or BT.
I've pasted some tracerts below, along with my router stats, just to see if there's anything there that might stand out as being a problem!  Thanks for any help you can give me!
Tracing route to bbc.co.uk [212.58.253.67]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms BThomehub.home [192.168.1.254]
2 5 ms 5 ms 5 ms 217.32.145.0
3 8 ms 39 ms 6 ms 217.32.145.46
4 12 ms 12 ms 12 ms 213.120.181.190
5 12 ms 12 ms 12 ms 217.41.169.229
6 13 ms 13 ms 12 ms 217.41.169.109
7 12 ms 12 ms 12 ms 109.159.251.229
8 26 ms 56 ms 24 ms core2-te0-0-0-6.ealing.ukcore.bt.net [109.159.21.159]
9 20 ms 19 ms 19 ms peer2-xe10-1-0.telehouse.ukcore.bt.net [109.159254.116]
10 21 ms 19 ms 23 ms 194.74.65.42
11 * * * Request timed out.
12 42 ms 24 ms 22 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
13 23 ms 23 ms 23 ms 132.185.255.156
14 24 ms 22 ms 22 ms www-vip.cwwtf.bbc.co.uk [212.58.253.67]
Trace complete.
Tracing route to game2.boundless-networks.co.uk [94.23.4.11]
1 1 ms <1 ms 1 ms BThomehub.home [192.168.1.254]
3 6 ms 6 ms 6 ms 217.32.145.46
6 13 ms 12 ms 13 ms 217.41.169.109
7 12 ms 12 ms 11 ms acc2-10GigE-9-3-0.sf.21cn-ipp.bt.net [109.159.251.223]
8 21 ms 23 ms 21 ms core2-te0-12-0-6.ealing.ukcore.bt.net [109.159.251.135]
9 20 ms 20 ms 20 ms peer1-xe10-1-0.telehouse.ukcore.bt.net [109.159.254.110]
10 * 46 ms * ldn-1-6k.uk.eu [178.33.103.232]
11 24 ms 22 ms 24 ms rbx-g1-a9.fr.eu [213.251.130.73]
12 26 ms 22 ms * vss-1-6k.fr.eu [94.23.122.169]
13 27 ms 26 ms 26 ms game2.boundless-networks.co.uk [94.23.4.11]
Trace complete.
Tracing route to 87.117.193.98 over a maximum of 30 hops
1 <1 ms 1 ms 1 ms BThomehub.home [192.168.1.254]
2 5 ms 6 ms 5 ms 217.32.145.0
3 5 ms 6 ms 5 ms 217.32.145.30
4 12 ms 11 ms 11 ms 213.120.181.66
5 11 ms 11 ms 10 ms 217.41.169.229
6 27 ms 36 ms 49 ms 217.41.169.109
7 81 ms 53 ms 47 ms 109.159.251.201
8 19 ms 19 ms 17 ms core2-te-0-13-0-12.ealing.ukcore.bt.net [109.159.251.177]
9 16 ms 15 ms 18 ms peer2-xe10-1-0.telehouse.ukcore.bt.net [109.159.254.116]
10 17 ms 15 ms 15 ms 195.99.126.129
11 18 ms 38 ms 17 ms iomart.londra32.lon.seabone.net [89.221.43.106]
12 16 ms 16 ms 17 ms 593.net1.north.dc5.as20860.net [62.233.127.174]
13 34 ms 19 ms 21 ms 87.117.211.42
14 18 ms 19 ms 19 ms 87.117.193.98
Trace complete.
Tracing route to go-cs.org [88.198.45.185]
3 6 ms 5 ms 6 ms 217.32.145.46
4 11 ms 11 ms 11 ms 213.120.181.66
5 11 ms 11 ms 11 ms 217.41.169.229
6 11 ms 11 ms 11 ms 217.41.169.109
7 43 ms 9 ms 11 ms 109.159.251.209
8 15 ms 15 ms 18 ms core2-te0-0-0-6.ealing.ukcore.bt.net [109.159.251.159]
9 19 ms 18 ms 15 ms peer1-xe9-1-0.telehouse.ukcore.bt.net [109.159.254.108]
10 26 ms 24 ms 24 ms linx-1.init7.net [195.66.224.175]
11 34 ms 39 ms 36 ms r1nue1.core.init7.net [77.109.140.254]
12 35 ms 36 ms 36 ms gw-hetzner.init7.net [77.109.135.102]
13 35 ms 35 ms 35 ms hos-bb2.juniper1.rz13.hetzner.de [213.239.240.133]
14 40 ms 37 ms 37 ms hos-tr1.ex3k12.rz13.hetzner.de [213.239.224.13]
15 58 ms 35 ms 35 ms go-cs.org [88.198.45.185]
Trace complete.
Tracing route to ns206284.ovh.net [94.23.45.43]
3 5 ms 5 ms 5 ms 217.32.145.46
6 12 ms 12 ms 12 ms 217.41.169.109
7 33 ms 39 ms 39 ms 109.159.251.241
8 52 ms 31 ms 39 ms core2-te0-0-0-6.ealing.ukcore.bt.net [109.159.251.159]
9 89 ms 20 ms 20 ms peer1-xe10-1-0.telehouse.ukcore.bt.net [109.159.254.110]
10 * * * Request timed out.
11 24 ms 24 ms 24 ms rbx-g1-a9.fr.eu [94.23.122.66]
12 26 ms * 46 ms vss-1-6k.fr.eu [94.23.122.169]
13 36 ms 43 ms 40 ms ns206284.ovh.net [94.23.45.43]
ADSL Line Status
Connection Information
Line state:Connected
Connection time:5 days, 22:44:16
Downstream:23.34 Mbps
Upstream:1.117 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):2.9 dB / 6.4 dB
Line attenuation (Down/Up):2.7 dB / 2.8 dB
Output power (Down/Up):17.9 dBm / 9.9 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):2439 / 358
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):8170 / 222
Error Seconds (Local/Remote):2250 / 193
9 REPLIES 9
Message 2 of 10
Re: Ping spikes
the traceroutes and hub stats are fine nothing wrong with the connection
Message 3 of 10
Re: Ping spikes
Yeah, I have no idea why it's doing it.
Could it be the 3DB profile causing the issue?  Or something within the BT network?
The only reason it's not been connected 24/7 for longer is because I manually rebooted the router because I thought that would fix the problem.
Message 4 of 10
Re: Ping spikes
resetting the router is unlikely to improve your connection and in most cases will make matters worse.
you connection has remained stable with the 3db noise margin and not a large number of errors for 5 days connection
Message 5 of 10
Re: Ping spikes
your connection and ping times are very good
Message 6 of 10
Re: Ping spikes
Thanks for the replies.
Yeah, I think I've managed to track it down to certain situations.  If I'm listening to music on Spotify, or listening to a music video on youtube, and I play online PC games at the same time, I seem to get ping spikes for 4-5 seconds every so often, that I never got with BE.  Is that likely to be something with the Homehub?  Or the BT network as a whole?
If I exit Spotify, it stops spiking, so I'm pretty sure they're both linked, since there appears to me nothing wrong with my connection stat wise.  I also changed my ethernet port today to the gigabit one on the Homehub, rather than the 100mb.
It's not really an issue, but I do like to listen to music while playing games, so it is a bit annoying it does that.  Could it be the amount of packets being sent/received at the same time that is causing the problem?
Here are my stats again below, and thanks for any suggestions you can provide me with!
ADSL Line Status
Connection time:10 days, 07:42:09
Upstream:1.117 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):2.7 dB / 6.4 dB
CRC Events (Down/Up):4720 / 829
HEC Events (Down/Up):15848 / 526
Error Seconds (Local/Remote):4317 / 487
Message 7 of 10
Re: Ping spikes
Spotify is P2P, at least in part, so it is probably the upstream causing the spikes.
You could either limit the library Spotify sees by moving music elsewhere so there is less to share, and therefore potentially less abuse of your bandwidth, or use something like Netlimiter to restrict the upstream available to Spotify.
Message 8 of 10
Re: Ping spikes
also unless you started your BT Broadband contract after 1st of February or have recontracted to the new fully unlimited product p2p protocols are capped at peak times
Message 9 of 10
Re: Ping spikes
Ohh, that would make sense then, Malfukshun! I have half the upload speed that I had with BE, and if I upload any more than 500/600kb/s while playing games, it makes my ping jump.
I'm on the 'totally unlimited' package, as I've only been with BT for about 18 days, so I don't believe I have any limits on my connection at all.
Message 10 of 10
Re: Ping spikes
no in that case you are unlimited as to your upload speed you have nearly the maximum available  on ADSL2+which is 1.2mb you cannot get any faster on a residential line
