Keith57
Message 1 of 6
Pinterest images not loading up
Hi, quick question just upgraded to infinity 2 with smart hub, got the speed up to 76 with the help of the open reach engineer visit to reset exchange. Now cannot use the Pinterest app on iPad as the images do not load.
if I change connection to bt fon it works log back in under the hub it does not.
so any ideas what the difference between the connections are as it’s from the same router ?
thanks
5 REPLIES 5
Keith57
Message 2 of 6
Re: Pinterest images not loading up
Spotty just found another thread further down which may resolve question
Keith_Beddoe
Message 3 of 6
Keith57
Message 4 of 6
Thanks Keith, just changed dns settings on iPad as per other thread and it now works
thanks
Keith_Beddoe
Message 5 of 6
It looks like the random DNS server issues that have plagued BT for many years. Somewhere, there are some BT DNS servers which are not refreshing from the DNS root.
I use OpenDNS on my router, so I do not get this issue.
XRaySpeX
Recognised Expert
Message 6 of 6
@Keith57: You're welcome :)! Glad my method could be of assistance.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
