Sp1der
Message 1 of 2
Pinterest problem
Hi all.
I'm hoping that someone here will be able to help me with this odd problem.
I can't visit the pinterest site, on any PC/Laptop/phone connected via my wifi.  If I turn wifi off on my phone, I can visit it straight away using the phone data connection.  At the minute I haven't noticed any other site blocked.  Has anyone ever had this?  It seems like my Homehub 5 has for some reason blocked access to pinterest?
I have the parental filter switched on for my account but it displays a particular message if it's a blocked site so that isn't the problem.
Any ideas greatly appreciated!
1 REPLY 1
Sp1der
Message 2 of 2
Solved:Re: Pinterest problem
OK,
solved this myself but will leave a message here just in case anyione else hits the same thing.
Basically, I added pinterest.com to the safe list in the parental controls.
It threw me at the start as it didn't display the usual "**** has been blocked by BT Parental Controls" message.
It just timed out instead...
Hope it helps someone.
