Lurgy163
Message 1 of 32
Pinterest
Anyone else having problems with BT smart hub not loading Pinterest.com ?
Have tired different browsers and works fine on my phone over 4G connection.
Either wont load or load except pictures are blank or just coloured panels
Any ideas on a fix ? must be BT smart hub blocking it for some reason ?
T
31 REPLIES 31
XRaySpeX
Recognised Expert
Message 2 of 32
Re: Pinterest
Such problems are often DNS issues. Can you change yours?
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Lurgy163
Message 3 of 32
Re: Pinterest
I would. But I dont know how. Tried contacting BT support but havent got very far
Keith_Beddoe
Message 4 of 32
Re: Pinterest
Just restart the home hub.
Lurgy163
Message 5 of 32
Re: Pinterest
tried that a few times
Liam_
Recognised Expert
Message 6 of 32
Re: Pinterest
If it's a Windows machine change the DNS servers in the Network Connection Properties.  See image.
Keith_Beddoe
Message 7 of 32
Re: Pinterest
You will need to flush any locally cached DNS results.
If its a Windows computer you are using, then type this at the address prompt
ipconfig /flushdns   (there is a space after ipconfig)
Windows does tend to cache old invalid DNS records, so that should clear them.
Lurgy163
Message 8 of 32
Re: Pinterest
I a mac user but I have found the dns settings and cleared out. restarted hub and browser. Still no result ??
Liam_
Recognised Expert
Message 9 of 32
Re: Pinterest
Looks like you might have to try changing the DNS servers after all.  Search Google for  change dns servers on MAC
Keith_Beddoe
Message 10 of 32
Re: Pinterest
Is that the only site affected?
What message do you see when you try to access the site?
