seems to be the only site affected at the moment ( have recently upgraded ). It either dosent load at all or loads but without image content.
My wife uses Pinterest all the time with hh6 but on windows 10 and never has any problems
I have been as well for the last few weeks but all change over the last few days
From what I've heard described the Pinterest page contains loads of links to images & therefore loads of DNS lookups.
Can you please run a BT Wholesale Speed test, including the diagnostics page?
Yep I think that is the case and every image has links to other sites. Not sure why the hub cannot sope though ?
If there had been any access problems I certainly would have heard about it I assure you
You could try & get round this issue by switching the DNS to Manual in the router, if it allows it or on your PC otherwise, with 1 of these public DNS:
Open DNS : 208.67.222.222 & 208.67.220.220 Google DNS: 8.8.8.8 & 8.8.4.4 Norton DNS: 198.153.192.40 & 198.153.194.40
Will that affect the performance of other websites ?
Is there any disadvantage to ditching the BT one for a public one ?
ds 31.39
us 16.57
p 22.50
