settle_john
Message 1 of 5
Plan change, upgrade
Hi
i have BT Sim only plan, can i upgrade to a mobile phone plan using my existing BT Sim.
4 REPLIES 4
mcronline
Message 2 of 5
Re: Plan change, upgrade
I believe you can yes but you would have to pass a credit check. It doesn't matter how long you have been a customer or how much so spend, its part if the process
Mancunian01
Message 3 of 5
Yes you can.
Bear in mind though that you'll be put on the allowances of the current package - so if you're on the 20gb data allowance now, you'll only get 15gb after the change.
NeilO
Moderator
Moderator
Message 4 of 5
@settle_john check out this link for more info.  You can order here and make sure to click on yes when it asks if you are already a BT Mobile customer?
settle_john
Message 5 of 5
Thanks everyone for the info I will check it out.
