Message 1 of 6
Please Help!!!! Download Speeds Dropped Shockingly!!!!!!!!
Hi
I am currently paying for BT Infinity 2 and last week i was revieving 75mbps on average most nights. All of a sudden this has now dropped to below 3mbps and doesnt get any better. When i perform speedtests wirelessly on Speedtest.net it shows ping of 30ms, download of 0.6-3.7mbps and upload of 18mbps. When i do these tests wired it shows ping 30ms, download 2-5mbps and upload of 18mbps.
When i do the test on Speedtest.BTwholesale i states i get 68mbps wired and 32mbps wirelesly but when using my console/phone i know this not to be true at all.
Please fix this.
5 REPLIES 5
Message 2 of 6
Re: Please Help!!!! Download Speeds Dropped Shockingly!!!!!!!!
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
Message 3 of 6
Helpdesk:
1. Product name:BT Home Hub
2. Serial number:+068543+NQ50211434
3. Firmware version:Software version 4.7.5.1.83.8.222.1.1 (Type A) Last updated 18/02/16
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:32:33
6. Data rate:19999 / 78929
7. Maximum data rate:26419 / 78830
8. Noise margin:15.3 / 5.9
9. Line attenuation:18.7 / 16.2
10. Signal attenuation:18.6 / 16.2
11. Data sent/received:4.3 MB / 28.3 MB
12. Broadband username:
bthomehub@btbroadband.com
btspeedtester:
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 68.93 Mbps
0 Mbps76.4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 68.93 Mbps
 For your connection, the acceptable range of speedsis 61.12 Mbps-76.4 Mbps .
 Additional Information:
 IP Profile for your line is - 76.4 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 13.21 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 13.21Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Wholesale FTTC Check:
  HighLowHighLow
FTTC Range A (Clean)75.257.42018.8--Available
FTTC Range B (Impacted)58.930208.4--Available
WBC ADSL 2+Up to 11.5--10 to 13Available
WBC ADSL 2+ Annex MUp to 11.5Up to 110 to 13Available
ADSL MaxUp to 6--5 to 7Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
Message 4 of 6
I also forgot to mention there are 4/5 people on the same street i have spoken to who are having the same problem
Message 5 of 6
Im using a Macbook Pro which is wired when performing the tests. I have a Airport Extreme plugged into my HH5 port 1. Soon as i plugged it in i was acheiveing top speeds until this weekend.
Message 6 of 6
can you please re post the BT Wholesale speedtest results when you connection starts to slow down as it is not showing any problem currently
