snak3uk
Message 1 of 3
Please can I have my Noise Margin lowered *again*
Message sent to StephanieG, who was very helpful last time.
Please can I have my noise margin lowered back down to 6 again?
Although it is plugged 24/7 into the test socket, it has crept up again over the last 6 weeks, until another disconnect 10 minutes ago.
Maybe BT would consider, in future HH firmware updates, allowing users to negotiate their own SNR margin, without having to go through this forum?
Cheers,
Tim
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:04:13
Downstream5,920 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)14.2 dB / 27.0 dB
Line attenuation (Down/Up)27.0 dB / 17.5 dB
Output power (Down/Up)
19.8 dBm / 12.4 dBm
2 REPLIES 2
Message 2 of 3
Re: Please can I have my Noise Margin lowered *again*
suggest you get interleaving turned on that is what is causing your line problems and instability
Geoff93
Recognised Expert
Message 3 of 3
I think it is unlikely that BT will ever update the HH to allow users to change their noise margin as it would give them even more support issues. If you wish to continue with a latency type of FAST then I suggest you invest in a router that allows you to specify the noise margin. This thread mentions 1 such router - http://community.bt.com/t5/BB-in-Home/Last-chance-saloon-really-Absolutely-fed-up/td-p/77569
