annesley23
Message 1 of 2
Please can someone help - Constant broadband reseting and low IP profile
HI,
Over the past two years i have continued to have issues with my broadband. These range from loss of connection, low speeds, reduced ip profile etc...
Ive posted some stats for you to see. At the moment the speed has dropped to half what it is normally.
Many thanks in advance for any help.
Michael Hughes
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 1:52:47
Downstream3,069 Kbps
Upstream1,016 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)8.7 dB / 5.7 dB
Line attenuation (Down/Up)49.0 dB / 29.0 dB
Output power (Down/Up)0.0 dBm / 12.8 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)5116 / 0
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)0
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download  Speed
 2.58 Mbps
0 Mbps4 Mbps Max Achievable Speed
 Download speedachieved during the test was - 2.58 Mbps  For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.  IP Profile for your line is - 2.71 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.92 Mbps
0 Mbps0.83 Mbps Max Achievable Speed
Upload speed achieved during the test was - 0.92Mbps  Additional Information:  Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time. It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly. If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
1 REPLY 1
Message 2 of 2
Re: Please can someone help - Constant broadband reseting and low IP profile
Hi Welcome to the forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
