Bigmac77
Message 1 of 65
Please check out my stats?
It's been over 48hrs since my noise reset. Connection had been stable until homehub reset earlier today, don't know why? I have been keeping an eye on my stats and my error second count seems quite high is this caused by me being on fast rather than interleaved? Speed good though getting about 3.5Mbps.
Here are the stats.
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 6:07:06
Downstream4,288 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)3.4 dB / 21.0 dB
Line attenuation (Down/Up)54.0 dB / 31.5 dB
Output power (Down/Up)18.4 dBm / 11.8 dBm
Loss of Framing (Local)113
Loss of Signal (Local)23
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)5359 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)3096
64 REPLIES 64
Message 2 of 65
Re: Please check out my stats?
stats look ok and as you are on fast there are no fec errors but crc and error seconds but not large for 6hrs connected.  crc up errors are a firmware bug
Bigmac77
Message 3 of 65
I thought so about the CRC up errors because the figure has been the same for ever.
The error seconds previously were some thing like 500 after 4 days, but if you think the count is still low then I'm happy.
The mods asked me to email them after the weekend and let them know how things were going so I just wanted to check with you guys.
Message 4 of 65
looking ok at the moment just keep us posted
Bigmac77
Message 5 of 65
Connection has reset again just shy of 48 hrs, sync speed has now reduced from 4228Kbps to 4096Kbps. Nosie margin was at 3.2 dB earlier and now 6.6 dB since it reset.
Here are the stats? Any ideas?
ADSL line status
Line stateConnected
Connection time0 days, 3:39:08
Downstream4,096 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Latency typeFast
Noise margin (Down/Up)6.6 dB / 20.0 dB
Output power (Down/Up)18.3 dBm / 11.9 dBm
Loss of Framing (Local)116
Loss of Signal (Local)24
CRC Errors (Down/Up)2356 / 2147480000
Error Seconds (Local)6200
Message 6 of 65
The disconnections will have caused a reset of noise margin in an attempt to stabilise your line just keep an eye on your connection for now
Message 7 of 65
looks like the low noise margin about 3 db was a bit low and router has reset and increased back to 6 with a small drop in connection speed.  now need to leave and see if stabilises at that.  may have to go to interleaved if keeps dropping
Bigmac77
Message 8 of 65
The mods reset the noise margin to 6 dB it then fell to around 3, what causes it to drop?
Message 9 of 65
at the time you posted the stats about 11pm that would be near the lowest point of your noise margin before it starts to incresae again.  usually highest about midday and drops during day and lowest about 11/11.30pm and then starts to increase to get t high point about midday again
Message 10 of 65
There have been trials to see if lines can support a lower noise margin if a line is seen as stable it will drop it to 3dB however it does not always turn out to be stable enough it will increase it back to the default 6dB as has your line
