Alanrf
Message 1 of 8
Please clarify difference between SpeedTester and SpeedTester Beta
I am aware the the basic BT Speedtester has been flaky, to say the least, for the past few weeks.  Sometimes it works but most times fails and gives a download reading of around 0 Mbps.
Using the beta version, which worked every time, gave more realistic readings and more in line with those that I have recorded over the last year or so.
Just now, as a check, I carried out tests on both versions, within minutes of each other.
BT Speedtest gave 6110 down, 830 up
BT Speedtest Beta gave 8860 down and 860 up.
The latter readings are more in line with my experience over the past 12 months and also correlate well with independent speed tests.
The upload speed is pretty consistent and seems to be a realistic assessment, but the difference in download  speeds between the two version is rather more puzzling.
Until the end of January I was advised that the " IP Profile for your line is - 10043 Kbps"
Since then I have been advised that the  "IP Profile for your line is - 9.08 Mbps"
The change in units probably reflects some software changes and is unimportant.
I assume that  the profile is always going to be higher then the actual, (at least it always has been), so I am not particularly concerned.
However there does seem to be a significant difference between the two test results.
Any ideas?
_________________________
Alan
7 REPLIES 7
Message 2 of 8
Re: Please clarify difference between SpeedTester and SpeedTester Beta
your profile is set by your connection speed and should be 88.2% of the conenction speed - so changing profile apart from different measures shows a difference in your connection speed.  the change to Mbps is very recent
I agree both versions ob BTspeedtester should give the same results or at least very similar but I certainly am not confident of the figures provided by the btspeedtester test not beta as over the last week mine has been all over the place.  the download speed from the beta version is always about right based on the speed I can download data at from othe sites
Alanrf
Message 3 of 8
Thanks for that bit of info.  I had been unclear as to how the profile was set and your figure is clearly spot on.
According to my (Draytek) router my download speed is 10.296888, so that, by your figure the profile would be 9.081.
For what it's worth, my recent upload profile is 0.83 Mbps and my router reports 1.024592 so presumably the inverse ratio more or less apllies for upload speeds.
My current stats are
ADSL Information
  ATM StatisticsTX CellsRX CellsTX CRC errsRX CRC errs
  5645914446448160104434
  ADSL StatusModeStateUp SpeedDown SpeedSNR MarginLoop Att.
  ADSL2+(G.992.5)SHOWTIME102459210296888929
The SNR margin used to be around 6, when I had a higher speed, but now seems to hover around 9, but the apparent errors seem to have reduced quite significantly, if, that is, I am correctly interpreting the info.
It may be possible, if I do a power off cycle, that the router may find a faster connection but, to be honest, does it really matter.  My current connectivity seems to be perfectly satisfactory, although perhaps I am tempting fate by saying that.
Thanks for your response.  Much appreciated.
Alan
Message 4 of 8
if you maintain a stable connection for 3days the forum mods can reset your noise margin to the default 6db
Alanrf
Message 5 of 8
Sounds like a good idea.  How can I contact the mods?
Alan
Message 6 of 8
contact mods
can take up to 3 working days for mods to contact you
Message 7 of 8
This is a link to the Mods
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
Alanrf
Message 8 of 8
Thanks for the advice.  I'll look forward to an increase in speed now.
Alan
