AnnaM60
Message 1 of 14
Please help. Need engineer visit
We have had an ongoing fault for weeks. The engineer is puzzled and as they leave they state if this doesn't work phone back and we will come back out.
Latest visit last Thursday. He left saying if this doesn't work I will come back and do ( ...)
Problem is I can't get BT operator to rebook a visit. He said there is an MBOC which will be fixed soon and the problem will go away.
But I know that is nothing to do with my issue and I am just following the orders of the latest engineer.
So frustrating -why do they keep putting my faults as solved when they are not and we have to start again at the beginning?
Does it get any better or is leaving BT completely the best option?
Tags (1)
13 REPLIES 13
gg30340
Message 2 of 14
Re: Please help. Need engineer visit
You can leave BT if you want but unless you move to Virgin, your new Internet provider will be using the same line etc as BT so your line problem will still be there.
AnnaM60
Message 3 of 14
Yes this is the problem I thought.
We live 200 m from the exchange and the engineer can't locate the problem so supposedly he is trying a different fix every time.
Problem is requesting a return visit once they've gone. I'm not sure the engineer realises the lengths we have to go through to get them back.
AnnaM60
Message 4 of 14
200 metres not miles that is!
RobbieMac
Moderator
Moderator
Message 5 of 14
Hi @AnnaM60
Thanks for your post and welcome to the forum.
I'm sorry that your services have developed a fault.  Send over your details to us and we will check what's causing the hold up with the repair.
Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
AnnaM60
Message 6 of 14
I have sent you a private message @RobbieMac
gg30340
Message 7 of 14
You need to use the online form that will have been made available to you by clicking on the moderators name, not a PM.
AnnaM60
Message 8 of 14
I didn't see a link to any form?
gg30340
Message 9 of 14
I'll get the moderator to repost it.
AnnaM60
Message 10 of 14
Sorted it. Thanks.
I'm on the mobile site. It's a different layout.
