Message 11 of 19
Re: Please help: Severe BT Infinity 2/Home Hub 5 wifi issues
I've spoken to BT who have tested the line and they say it's fine - "only" two drops off in the last 7 days.
They're sending a new HH5 although I'm sceptical that will make any difference.
If it still doesn't work then they are sending an engineer.
I've tried different channels rather than auto select and the same problems exist.
Thanks for your help with this.
Message 12 of 19
I am still experiencing serious wifi issues and have had no service for nearly 48 hours.
BT sent an engineer who reported no issues with broadband and advised it must be wireless interference. I understand the logic, as the light on the HH5 is always blue but I remain unconvinced.
Firstly, how can I detect "wireless interference"?
Secondly, the only possible common theme we can identify is that the wifi doesn't work when it's raining or damp - could this suggest the wiring or not?
Message 13 of 19
Download an app called wifi analyser or innsider on a phone, or innsider ( double n) on a pc and open then up. It will show clearly what networks are around you and on what channel. Last year I had to resort to getting my neighbours to arange non conflicting channels as interference was affecting our signals.
Message 14 of 19
you can try downloading inssider3 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
inssider3.1.2.1
check here for possible inteference causes
interference causes
you can also check for rein using a portable radio tuned to 612MW  http://www.kitz.co.uk/adsl/rein.htm
Message 15 of 19
Thanks for your suggestions.
Is innsider free? I clicked on the link but was asked for Licence key.
As the weather has been drier, the wifi has again improved.
I presumed the wifi extenders could not be a source of the problem but could they? They flit between red, green and yellow. When on red, does the wifi therefore just come from the hub and the extender is ignored, or could the extender in effect blobk the signal being transmitted further?
Message 16 of 19
There should be a free version, but if you cannot find one, there is an earlier version on my website
http://forumhelp.dyndns.info/software/insidder.zip
Message 17 of 19
the link is still to free version but did you select the free trial of inssider office?
Newbie
Message 18 of 19
Hi did you ever fix this issue?
This definitely sounds like wifi interference to me. Have a think of everything and anything that is wifi or wireless of some description. Do you have any environmental monitors etc. I've had bad experiences myself in the past with customers premises that the wifi is operating in and had one where there was absolutely no signal being broadcasted at all from an enterprise grade wifi point in one part of the building. After days of troubleshooting finally found the signal was being blocked by a environmental monitor that the manufacturer "guaranteed wouldn't interfere with wifi" not the customers fault. Moment I turned the thing off everything started to work.
Incidentally that signal was not detected with insider as I ran all the tests.
Hope this helps someone!!
Message 19 of 19
My wifi has improved. I changed a cable that ran from the BT box into the house, moved the router into a more central position, and also made my Apple Time Capsule to be my router. Which one or combination of those three made the difference I'm not sure but, for the moment, it's improved.
