Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Solved! Go to Solution.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Have you tried unplugging the YouView box, then plugging it back in, so it restarts from the beginning?
Hi @Wigno6
Thanks for posting and welcome to the community. This is something we would need to look at so can you send in your details by clicking on the contact link within my profile and once of the team will be in touch as soon as possible.
Cheers,
OlgaC
Hi @Wigno6 Thanks for taking my call earlier and sorry to hear that your parents are having the same error. Please drop me in their details and I'll get a fault raised for them also. I've enabled the link for you under my profile.
Cheers
John
Hi @Wigno6 Sorry this has not been fixed yet for you. I am chasing an update and will be in touch as soon I have some information for you.
Cheers
John
Hi to all on this thread. IPC6023 dialog message (Blank Screen then IPC6023 after a few seconds) means you aren't recieving multicast/internet channels (stating the obvious).....If it's IPC6023 on all channel including 399 (test channel) and you've only recently signed up, i'd put money on this being a config issue. The way forward should be a fault raised into BT Consumer and passed to Openreach for a multicast config check. I'm more than happy to take this on and get resolved. Please privately post your telephone number or account number to me and i'll own to resolution. Note:- IPC6023 dialog isn't always this problem -= please make sure your home setup has been thoroughly checked. For example - You may be using a switch, placed between your router and set top box. This 3rd party switch may not be able to support IGMP, therefore, no multicast. Make sure you are setup using direct ethernet cable between router and box
Hi @Jay_Nix
I'm also getting the same error, however I'm not a new BT TV customer. I recently had my faulty HH3 replaced with a Smart Hub, at first everything including all TV channels worked fine, but the past couple of days Extra channels have stopped working.
My fault has just been escalated to the Technical Management Center and I'm expecting a call from then within 24hrs.
However, I notice you mentioned the 399 test channel which IS actually working for me, but all other subscription channels do not. I have the TV Box connected directly to the Smart Hub via Ethernet.
Is there anything I can try in the mean time (we have already tried a Factory Reset of Smart Hub AND Youview Box) or is it best to just wait for the call?
