Hi All,
I wish someone could solve my problem. BT upgraded the exchange in mid-February. I received this email on the 16th -
Good news
This is to let you know that we've now upgraded your line and you should now have an improved, more consistent broadband connection, and maybe a speed increase.
I had a very good connection before the upgrade. Consistently 7mb on an IP Profile of 7150 on ADSL Max. Anyway since the upgrade things have deteriorated somewhat. Consistency is not one of the services being offered. Service varies between nothing at all - even broadband light on HomeHub3 going out - and 6.9. I have been logging it every half hour during the day. Naturally I have been in touch with BT Service Desk and they have been ringing me every 2 days to see if things have improved! I have had an engineer out and he said the line was 'sweet' and capable of good speeds. He suggested the exchange should change me onto a 21CN circuit as I was on ADSLMax. He spoke to the exchange and they said to request it through BT Service Desk. I did so and they have said they have done it, but it really has made no difference. It IS worse than before the upgrade. I have checked out the line via KITZ and this gave me:
Estimation of your maximum rate adaptive adsl speed
Downstream Attenuation dB 24.0
Approx Line Length 1.7 km
dslMAX 8128kbps IP Profile 7150kbps
adsl2+ (21CN) 18688kbps IP Profile 16000kbps
adsl2+ (LLU) 18688kbps Throughput 16539kbps
BT Speedtester shows:
Download speed achieved during the test was - 5.16 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.11 Mbps
Speedtester then came up with:
We have identified that you have additional services enabled on you broadband line, please click continue to run advanced service tests.
Except I don't have additional services on my line, e.g. video, TV. So what's that about too?
I believe I should gett a much more consistent, and higher, speed. I did before BT upgraded the exchange. Normally, I would let BT just get on with it. I am ex-BT TO and have remained 'loyal' to the old firm and have never used anyone else. But I am signed upto the £25 a month deal, and I have recently renewed it for another 18 months. So, this is beginning to irk me somewhat.
Any ideas what I should do next? All help will be gratefully received.
Thank you.
Roy
ADSL2+ utilises a much larger frequency spectrum to acheive the same speed. If anything is restricting this, then your speed will be reduced.
Which type of master socket do you have?
One of these
Or one of these
Or if you are lucky
One of these
Hi,
Thanks for replying. I have the last type of master socket - lucky?
@RoyBennett wrote:
Hi,
I am assuming that you have your home hub plugged into the small front socket?
Can you please provide your full ADSL stats
then I can see what the current status is.
Hi,
Yep, all wiring is o.k. - checked out fully by BT engineer on his visit. My HomeHub3 settings are:
ADSL Line Status
Connection information
Line state: Connected
Connection time: 2 days, 19:07:50
Downstream: 8,064 Kbps
Upstream: 448 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 11.6 dB / 28.0 dB
Line attenuation (Down/Up): 24.0 dB / 11.0 dB
Output power (Down/Up): 19.8 dBm / 11.1 dBm
FEC Events (Down/Up): 1712 / 50
CRC Events (Down/Up): 56 / 12
The line is still playing up - BT Service Desk will be ringing me, again, tomorrow. Something about the exchange engineers having problems getting my line to set a consistent speed.
Cheers,
Roy
You have not been upgraded, you are still on the old ADSL service.
It does not happen automatically, you have to ask to be upgraded.
Did BT agree to do this when you renewed?
Hi,
This is confusing me now. In my original post I said that I had requested the circuit be upgraded and I have been told several times since by BT Service Desk that the work has been carried out! How do I make sure that this is done? Also what are the indicators in my ADSL settings that tell you that I haven't been upgrade?
Cheers
Roy
@RoyBennett wrote:
Hi,
Cheers
Roy
Upstream: 448 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
You have been mis-informed I`m afraid.
Your best course of action would be to ask the BT Care Team, they will get to the bottom of this.
If you would like to contact one of the UK based BT Care Team who moderate this forum, they should be able to help you.
They can be contacted using this link BT Care Team
They normally respond by phone or e-mail, within three working days, however you should get an immediate confirmation, with a tracking number.
Thank you for your help. I have sent an email to the Care Team as suggested and with the details they have requested. The system gave me an enquiry reference number - how do I use it to track the progress of my problem?
BTW, my line as dropped off a cliff since the last email. BT Speedtester barely registers it when testing - most of the time it shows 0.00 with occasional surges. This does tend to bias the average speed it shows - but it is crawling along at the moment.
I hope the Care Team can help.
Cheers,
Roy
Keep a note of the tracking number, you will receive an e-mail when it is your turn in the queue.
The BT Care Team take ownership of the issue until it is resolved.
