Words
Message 11 of 18
Re: Poor Wireless Speed
Th eonly thing I can think of is to check the properties on your wireless adapter. It may be defaulting to 'b'. You may need to do a search to find how to adjust it. I'm on the limits of my knowledge.
MBR123
Expert
Message 12 of 18
I tried WPA 2 Only and all it did was slow my connection down about 200 - 300 kbps and load times were terrible. Stick with yes 40mhz n but keep with WPA & WPA 2 Only recommended.
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
DelSP10
Message 13 of 18
@mb199143
What laptop are you using?
mb199143
Message 14 of 18
HP Pavilion G6
mb199143
Message 15 of 18
So it appears that the wireless signal is fine close to the home hub, i can get up to around 40mbps over wireless sat right next to the hub, however it is stuggling over a greater distance (in next room- only about 20m away) so I am therefore going to assume I need a wireless booster that can transmit over a greater distance. Can anyone recommend one that they may have used themselves? Also would this be used as well as the home hub or in conjuction with?
jamjar62
Expert
Message 16 of 18
I have  Dell XPS  Laptop with a Intel 6300 N WiFI Card inside and i,m sat about  6m away from the Hub 3 and i get 66Mbps     sometimes dlightly more , i have Powerlines AV500 installed too 🙂
JamJar62
biffo1963
Message 17 of 18
You might also care to try changing the wireless channel and seeing if that improves things.  My HH3 defaults to Channel 1 if I leave it on Automatic, but although none of my neighbours are on that channel something else sometimes interferes with Channel 1  -  something that even InSSIDer cannot see !  If I change to Channel 11 everything is perfect, despite several other local routers usng the same channel.    As the Americans say, go figure...........
jamjar62
Expert
Message 18 of 18
Yeah thats strange mine defaults to channel 1 also and sometimes 11 I can,t say i,ve had any problems on wireless at present , and i think there is only 3 people on Infinity in my road most are on Virgin 😞
JamJar62
