graydwyer
Message 1 of 75
Poor broadband speed
Never seems to have got much higher than below in 2-3 years, thi is plugged into the test socket also, can anyone check into this?
Line stateConnected
Connection time0 days, 0:00:35
Downstream2,611 Kbps
Upstream824 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)15.4 dB / 7.8 dB
Line attenuation (Down/Up)50.5 dB / 28.4 dB
Output power (Down/Up)18.5 dBm / 12.3 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)1 / N/A
HEC Errors (Down/Up)N/A / 764691
Error Seconds (Local)1
74 REPLIES 74
Keith_Beddoe
Message 2 of 75
Re: Poor broadband speed
Your maximum estimated speed would be 5152Kbs, however you appear to have been connected for only 35 seconds?
You must leave your home hub turned on and connected to your phone line for at least five days.
During that time, do not reset or disconnect it.
If your download speed has not increased after that time, then return to this thread for assistance.
Thank you
graydwyer
Message 3 of 75
I have been with BT for 2+ years and i took this reading after checking the speed in the test socket, what is going to be different about the next 5 days compared to the last 2+ years? Have you set something up to potentially fix in the next 5 days?
Keith_Beddoe
Message 4 of 75
Your downstream noise margin is high, which indicates that there is spare capacity to carry more data. The exchange however has reduced that capacity because it thinks there is instability on the line due to disconnections.
Leaving it connected for about five days should tell it that the line is now stable, and capable of carrying more data.
The downstream noise margin will then reduce to between 3 and 6db, and your speed will increase.
If that does not happen, and you can show that the line has been connected for five days, then it can be escalated to the BT Care Team.
john46
Message 5 of 75
This is a customer to customer self help forum the only BT presence here are the forum moderators
As Keith has posted your line has been seen as unstable and the five days gives the line chance to stabilise again  and your speed to improve
graydwyer
Message 6 of 75
ok thanks Keith
john46
Message 7 of 75
please post back with any progress
graydwyer
Message 8 of 75
will do thanks
graydwyer
Message 9 of 75
Update on connection - been no change at all yet. I cannot watch any on demand at all as I am getting v04 errors which is telling me to restart my home hub but i cant really as I need to leave on for 5 days...
ADSL line status
Connection information
Line stateConnected
Connection time1 day, 21:18:30
Downstream2,255 Kbps
Upstream800 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)17.3 dB / 7.5 dB
Line attenuation (Down/Up)50.5 dB / 28.5 dB
Output power (Down/Up)18.0 dBm / 12.2 dBm
Loss of Framing (Local)11
Loss of Signal (Local)1
FEC Errors (Down/Up)0 / 87
CRC Errors (Down/Up)4960 / N/A
HEC Errors (Down/Up)N/A / 764883
Error Seconds (Local)4595
john46
Message 10 of 75
just keep posting results please
