After suffering from similar change in broadband speed after 5pm (6/7mbs during the day and around 1.5 mbs thereafter) i have carried out the above mentioned steps and have the following reults:
using the bt speed tester:
however gievn that i couldn't stream content on any of my devices i used the "global standard for internet metrics" and got these results:
I find it somewhat convenient that using the bt speed tester I cannot complain as this is above the minimum 4.5mbs guaranteed by bt. Howevere, given that this is clearly an error i am unsure as to what my next steps should be. Could you please advise?
Many thanks
I have tried the quiet line test and there is no noise whatsoever on the line.
I've had trouble locating the exact logs you were asking for, however the most similar ones i could fined were these:
21:45:03, 28 Oct. | DSL Link Up: Down Rate=8023Kbps, Up Rate=1151Kbps; SNR Margin Down=9.2dB, Up=6.2dB |
19:17:37, 28 Oct. | DSL Link Up: Down Rate=8050Kbps, Up Rate=1148Kbps; SNR Margin Down=9.1dB, Up=6.4dB |
16:59:20, 28 Oct. | DSL Link Up: Down Rate=9586Kbps, Up Rate=1151Kbps; SNR Margin Down=6.1dB, Up=6.3dB |
13:17:33, 28 Oct. | DSL Link Up: Down Rate=9559Kbps, Up Rate=1156Kbps; SNR Margin Down=6.1dB, Up=6.4dB |
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
HighLowHighLowVDSL Range A (Clean)44.232.496.2--31-Mar-17----VDSL Range B (Impacted)35188.14.4--31-Mar-17----
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+Up to 17.5--14.5 to 20.5Available----WBC ADSL 2+ Annex MUp to 17.5Up to 114.5 to 20.5Available----ADSL MaxUp to 5--4 to 7.5Available----WBC Fixed Rate2 ----Available----Fixed Rate2 ----Available----
Other Offerings
Availability Date
VDSL Multicast------31-Mar-17----ADSL Multicast------Available----
this is a copy of the image i attempted to post yesterday
And this is a copy of the image of an alternative speed test checker:
please let me know if you need anything else
many thanks
