Wolfy
Message 1 of 46
Poor connection AND alot of dropping of connection
I recently moved house and i was very happy with bt at my old one never had a problem but now i have very poor connection and slow speeds i cant play online games as i get so much lag, ive waited almost 3 weeks now to see if the problem would sort itself as of the training in of the hub.
Things ive done to try to improve:
Forwarded ports for games
New filters,
Plugged in test port
Nothing eles is on the line except phone
I have a brand new high performance laptop
Quiet line test was fine
Changed router channels
Ran bt speed test and it cant retrieve my details properly but claims everything is good (it is not at all)
here is some details:
ADSL Line Status
Connection information
Line state:
Connected
Connection time:
2 days, 02:43:03
Downstream:
4,723 Kbps
Upstream:
879 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Fast
Noise margin (Down/Up):
6.5 dB / 6.0 dB
Line attenuation (Down/Up):
51.5 dB / 30.5 dB
Output power (Down/Up):
0.0 dBm / 12.8 dBm
FEC Events (Down/Up):
0 / 0
CRC Events (Down/Up):
45300 / 263
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
HEC Errors (Down/Up):
91463 / 213
Error Seconds (Local/Remote):
0 / 187
45 REPLIES 45
Wolfy
Message 2 of 46
Re: Poor connection AND alot of dropping of connection
i can post the event log if needed
Message 3 of 46
were the stats posted from the test socket?  you have a lot of crc/hec errors which could be causing a low throughput particularly at night when noise margin probably drops a bit lower
please can you try btspeedtester again
Wolfy
Message 4 of 46
They were from the master socket but not from the actal test port the front plate is still on but i dont have any extentions going from it
Wolfy
Message 5 of 46
speed tester is still saying it cant match all my details after continuing anyway it says my speed is 4.49mb download and 0.6mb upload
my hub reset itself new test resaults speed is still crappy
ADSL Line Status
Line state:
Connected
Connection time:
0 day, 00:33:53
Downstream:
5,184 Kbps
Upstream:
923 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Fast
5.9 dB / 5.8 dB
49.5 dB / 29.1 dB
0.0 dBm / 12.8 dBm
0 / 0
4 / 6
0 / 0
0 / 0
0 / 0
0
20 / 0
0 / 6
Guru
Guru
Message 6 of 46
Hi Wolfy,
From your adsl stats your line attenuation is 51.5dB which would make your landline approx. 3.7Km long between your property and the local exchange.
On a good quality line with a line attenuation of 51dB I would have estimated a downstream speed of around 4mbps to 4.7mbps.
Your currently synced at 4.7mbps on ADSL2 which is good for your line length.
Edit: now your currently synced at about 5.1mbps on ADSL2 which is good for your line length.
As imjolly has said, keep an eye on the errors and noise margin during the night/evening.
However at the moment the errors don't seem to be causing an issue with your throughput speed.
Your line latency is currently set as Fast, if the DLM thinks there are too many errors on your line it will probably set it to Interleaved.
Also the BT Wholesale speedtester is http://speedtest.btwholesale.com
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 7 of 46
try this version of the speedtest http://speedtest.btwholesale.com/
and post back the second test further diagnostics
Wolfy
Message 8 of 46
Best Effort Test: -provides background information.
 Download  Speed
 4.57 Mbps
0 Mbps7.15 Mbps Max Achievable Speed
 Download speedachieved during the test was - 4.57 Mbps  For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.  IP Profile for your line is - 4.57 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.62 Mbps
0 Mbps0.83 Mbps Max Achievable Speed
Upload speed achieved during the test was - 0.62Mbps  Additional Information:  Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time. It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly. If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Message 9 of 46
ok there is nothing wrong with the speed from that test
Wolfy
Message 10 of 46
I dont know what to say its proberly a case of things have fixed as i have someone to help just like the dishwaser will work fine when the repair man is here i will continue to monitor things and if it goes down hill i will post back if thats alright
current ADSL thingy: the errors are slowly creeping up is that normal?
ADSL Line Status
Line state:
Connected
Connection time:
0 day, 00:54:00
Downstream:
5,184 Kbps
Upstream:
923 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Fast
5.9 dB / 5.9 dB
49.5 dB / 29.1 dB
0.0 dBm / 12.8 dBm
0 / 0
11 / 6
0 / 0
0 / 0
0 / 0
0
28 / 0
0 / 6
