Message 11 of 46
Re: Poor connection AND alot of dropping of connection
The connection time is to low to make a decision on that if the connection suffers at night with the noise margin dropping to a low level and the errors increase rapidly then you may benefit in having interleaving turned on if the DLM does not do it automatically
Message 12 of 46
just keep checking and if problem returns then com back and post new stats.  there is always someone around to help
Wolfy
Message 13 of 46
Thankyou everyone good to see some actual helpful individuals on the tinterwebs
Wolfy
Message 14 of 46
Ok its been fine for a while and again its now turning **bleep** i keep being disconected the light flashes purple and orange then reconnects itself after knocking everything off the net, this is so annoying and shouldnt happen i keep seeing the error NO CARRIER on the log if thats any help the router resets itself all the time and it wont stay connected for more than a day without some sneaky reset
ADSL Line Status
Connection information
Line state:
Connected
Connection time:
0 day, 14:49:28
Downstream:
5,779 Kbps
Upstream:
939 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Fast
Noise margin (Down/Up):
1.7 dB / 5.9 dB
Line attenuation (Down/Up):
50.0 dB / 29.4 dB
Output power (Down/Up):
0.0 dBm / 12.7 dBm
FEC Events (Down/Up):
0 / 0
CRC Events (Down/Up):
6766 / 107
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
HEC Errors (Down/Up):
4096 / 47
Error Seconds (Local/Remote):
0 / 96
Message 15 of 46
it is you low noise margin that is causing the disconnections
tyr the suggestions in this link it may help you
http://forumhelp.dyndns.info/speed/noisemargin.html
Wolfy
Message 16 of 46
so disonecting the adsl wire for 20 seconds should improve it and if not who shall i contact
Message 17 of 46
try that first if the connection does not improve over 24 hours the you will need the forum mods assistance to reset the noise margin we can give you a link then if needed
Wolfy
Message 18 of 46
 Ok after 2 ''wire resets'' the margine hs risen what shoul i be aiming for or do i need to find out if i disconnect later on this evening again?
ADSL Line Status
Line state:
Connected
Connection time:
0 day, 00:10:40
Downstream:
5,687 Kbps
Upstream:
955 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Fast
3.1 dB / 5.8 dB
49.5 dB / 29.2 dB
0.0 dBm / 12.7 dBm
0 / 0
78 / 11
0 / 0
0 / 0
0 / 0
0
153 / 3
0 / 11
Message 19 of 46
keep checking the crc/hec errors and also if hub noise margin is starting to fall especially later tonight.  if so then getting latency changed from fast to interleaved would be my first recommendation followed by a reset of your noise margin to 6db - that wouls mean a slight reduction in conenction speed
Wolfy
Message 20 of 46
ok it just died on its asz i managed to grab this befor it reset all the stuff
ADSL Line Status
Line state:
Connected
Connection time:
0 day, 00:06:54
Downstream:
5,923 Kbps
Upstream:
920 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Fast
8,000.0 dB / 0.0 dB
-0.2 dB / 6.5 dB
50.5 dBm / 29.6 dBm
0 / 0
23078 / 0
0 / 0
0 / 0
0 / 0
0
1025951 / 0
0 / 0
To reset back to the default BT Total Broadband username and password, click the 'Reset username' button.
 Reset username
Plese wait...
Applying...
WAN Status
Line state:
Disconnected
Connection time:
Not available
