Wolfy
Message 21 of 46
Re: Poor connection AND alot of dropping of connection
ide like to add also that ''**bleep** out'' as i call it happened just as it started drizzling slightly coincidence maybe because it doesnt normaly happen with rain normaly
Wolfy
Message 22 of 46
ok its looking normal again Doctor i mean people
 the noise margine has changed itself lower again should i try the wire reset thing again?
ADSL Line Status
Connection information
Line state:
Connected
Connection time:
0 day, 00:22:03
Downstream:
5,743 Kbps
Upstream:
955 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Fast
Noise margin (Down/Up):
2.1 dB / 5.7 dB
Line attenuation (Down/Up):
49.5 dB / 29.3 dB
Output power (Down/Up):
0.0 dBm / 12.8 dBm
FEC Events (Down/Up):
0 / 0
CRC Events (Down/Up):
674 / 9
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
HEC Errors (Down/Up):
1360 / 2
Error Seconds (Local/Remote):
0 / 8
Message 23 of 46
i would try 1 more disconnetion, wait and then reconnect and see if noise margin will increase
more people are trying to reduce the noise margin as it drops easily  whereas you are tring to increase and having difficulty
Wolfy
Message 24 of 46
its at 3.1 and wont raise anymore if it does explode on itself and changes it back will a moderator be able to help
Message 25 of 46
yes the mods can get a reset done for you if it is needed
Message 26 of 46
only problem is it will not be fixed and will be subject to the automated system and may well drop back to 3db
Wolfy
Message 27 of 46
so what should i do as this constant dropping of connection is not any good and it is seriously getting beyond a joke
Message 28 of 46
i would leave it now 24 hours and see what happens then post back
Message 29 of 46
I would first get interleaved instead of fast and see if that stabilises your line.  mods can fix that
contact mods
can take up to 3 working days for mods to contact you
Wolfy
Message 30 of 46
ok it just reset itself to the lower again this is taking more than its fair share of the biscuit
Line state:
Connected
Connection time:
0 day, 00:01:23
Downstream:
5,863 Kbps
Upstream:
939 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Fast
1.0 dB / 5.6 dB
50.5 dB / 29.6 dB
0.0 dBm / 12.8 dBm
0 / 0
2 / 0
0 / 0
0 / 0
0 / 0
0
1 / 0
0 / 0
