Message 31 of 46
Re: Poor connection AND alot of dropping of connection
contact the mods as you have tried everything you can
contact mods
can take up to 3 working days for mods to contact you
Wolfy
Message 32 of 46
Ok it seems the mods have changed my settings things seem fine now anything eles thats looking like it needs attention?
ADSL Line Status
Connection information
Line state:
Connected
Connection time:
1 day, 06:53:58
Downstream:
5,334 Kbps
Upstream:
896 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Interleaved
Noise margin (Down/Up):
4.4 dB / 6.0 dB
Line attenuation (Down/Up):
49.0 dB / 29.2 dB
Output power (Down/Up):
0.0 dBm / 12.8 dBm
FEC Events (Down/Up):
80970 / 571
CRC Events (Down/Up):
404 / 32
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
HEC Errors (Down/Up):
2703 / 16
Error Seconds (Local/Remote):
0 / 26
Message 33 of 46
now interleaved with higher noise margin which should reduce the crc/hec errors and help the throughput at night.  just keep a watch on noise margin especially at night and see how low it drops
Wolfy
Message 34 of 46
Got up this morning to find no internet and the hub stats reading this, what on earth is going on and why is the hub being stupid it took me an hour just to get it to go back to normal stats in the end i just reset the thing, and i realise its not the best thing to do as it loses all its stats and stuff for you to look at
ADSL Line Status
Line state:
Connected
Connection time:
0 day, 00:54:22
Downstream:
5,259 Kbps
Upstream:
910 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Interleaved
8,000.0 dB / 0.0 dB
-1.9 dB / 5.5 dB
50.5 dBm / 29.6 dBm
1361184 / 75
150041 / 0
0 / 0
0 / 0
0 / 0
0
1789385 / 0
0 / 0
Wolfy
Message 35 of 46
After reset,
ADSL Line Status
Line state:
Connected
Connection time:
0 day, 00:04:56
Downstream:
5,155 Kbps
Upstream:
969 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Interleaved
6.0 dB / 6.3 dB
50.0 dB / 29.3 dB
0.0 dBm / 12.8 dBm
17551 / 41
177 / 0
0 / 0
0 / 0
0 / 0
0
1379 / 0
0 / 0
Message 36 of 46
second set of stats look ok but no idea how you managed to get stats like that
Wolfy
Message 37 of 46
ok internet as been fine all day now its got to evening its gone slow and i dont just mean slow im do mean unusable slow and im getting alot of HEC errors
ADSL Line Status
Line state:
Connected
Connection time:
0 day, 15:25:32
Downstream:
5,027 Kbps
Upstream:
929 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.3 Annex A
Latency type:
Interleaved
6.3 dB / 5.6 dB
50.5 dB / 29.5 dB
0.0 dBm / 12.6 dBm
2762535 / 1955
36036 / 58
0 / 0
0 / 0
0 / 0
0
774987 / 31
0 / 53
Message 38 of 46
As you say lots of hec and crc errors. Can you run btspeedtest to see what it shows as throughput and post results
Wolfy
Message 39 of 46
bt speedtest itself wont match my details so i did a wholsale one it says speed is fine but im getting slow load times and it does seem to be fluctuating alot online games is not happening at all
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download  Speed
 4.43 Mbps
0 Mbps4 Mbps Max Achievable Speed
 Download speedachieved during the test was - 4.43 Mbps  For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.  IP Profile for your line is - 4.43 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.73 Mbps
0 Mbps0.83 Mbps Max Achievable Speed
Upload speed achieved during the test was - 0.73Mbps  Additional Information:  Upstream Rate IP profile on your line is - 0.83 Mbps
Message 40 of 46
Btspeedtester looks ok. But the errors are very high are you still in test socket? Is quiet line test ok? Looks like back to mods especially after the -1.9db attenuation and 8000 noise margin
