Wolfy
Message 41 of 46
Re: Poor connection AND alot of dropping of connection
noise is fine just a slight hum as on cordless, yes still on test socket the strange stats only seem to be there if i cant get on the net but can conncet to the router
Wolfy
Message 42 of 46
Right, now things seem to be ok one moment then all of a sudden the wireless is dieing and i cant connect to the hub itself on any laptop via wireless i have to plug in to it and internet is there then after about 5 mins unplug and wireless returns, this happens with any of the 4 laptops in the house (not all are used at the same time usualy a max of 2 get used depending on who is here or what is going on) changing wireless channel seems to work but then ater about 10 mins of use the hub crashes resets itself and alas the same problems ive been having from before i have had a few emails from a mod asking some questions but it is slow going, i have also noticed when it rains the wireless just dies completely the moment rain stops it returns i dont know if its all the internet or just the wireless part of things as i cant predict when it rains but it is seeming like a factor in the problems.
Message 43 of 46
Outside rain should not effect your wifi in your home- may cause your internet connection a problem but not wifi. Has the mod suggested giving you a new hub?
Wolfy
Message 44 of 46
they have not should i bring it up? and should it be of any cost to me?
Message 45 of 46
I would ask for one but you will probably only get a hh3
Message 46 of 46
it would be worthwhile asking should be no cost
