grima00
Message 1 of 8
Poor connection on smart phone
Hi, my wireless computer is showing a fairly good download/upload speed, 4.3mbps and 820.48mbps, but my smartphone is only registering, 0.19 and 0.36. Has anyone got any idea why this should be.
7 REPLIES 7
Message 2 of 8
Re: Poor connection on smart phone
You're not connecting to BT wi fi (Fon) via your hub rather than your hubs bb signal by any chance?
AQ.
"Welcome to Royston Vasey - You'll never leave."
grima00
Message 3 of 8
Hi, how can I check that. As far as I am aware I am connected to the same wi fi as my computer.
Message 4 of 8
Go to settings on your phone, wi fi and you will see by which medium you are connected. Select your own hub rather than bt wifi.
AQ.
grima00
Message 5 of 8
Hi, Yes I an signed in to my own hub and my phone is telling me that the signal is very strong...
Message 6 of 8
That's odd. Try wiping all connection history from within your phones settings and then re-estalishing connection via your hub ensuring you dont go for BT wi fi of course.
You dont have any firewall protocols on your phone that inhibit wi fi connection do you?
AQ.
grima00
Message 7 of 8
Allan, thanks very much. All fixed and working fine now. I had downloaded AVG anti virus and it was this that was causing the trouble. I have now uninstalled it and everything is back to normal. Many Thanks.....
Message 8 of 8
That's good 🙂
If you mark this issue solved other's in the future will find it much easier.
AQ.
