Message 1 of 5
Poor line connection, high latency
Hi I currently am experiencing very slow broadband issues, I am connecting straight into the engineers socket and wired ethernet cable to PC. I am also running a ping test which has not droppe below 100ms for quite a while now. The speed test is giving me 1.21mbs but the ping is creating terrible latency problems. Please help/advise
Regards
4 REPLIES 4
Message 2 of 5
Re: Poor line connection, high latency
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 5
can you run a tracert using windows command prompt to bbc.co.uk
Message 4 of 5
Hi thanks for the prompt reply. I am using HH5 by the way
log gives this
18:34:34, 13 Jun.( 93.540000) PPPoA is up -​ VPI: 0, VCI: 38 Down Rate=2848Kbps, Up Rate=448Kbps; SNR Margin Down=9.1dB, Up=20.0dB
18:34:34, 13 Jun.( 93.530000) CHAP authentication successful
18:34:34, 13 Jun.( 93.270000) CHAP Receive Challenge
18:34:34, 13 Jun.( 93.270000) Starting CHAP authentication with peer
18:34:34, 13 Jun.( 93.270000) PPP LCP Receive Configuration ACK
18:34:34, 13 Jun.( 93.240000) PPP LCP Send Configuration Request
18:34:32, 13 Jun.( 91.620000) PPP LCP Send Configuration ACK
18:34:32, 13 Jun.( 91.620000) PPP LCP Receive Configuration Request
18:34:31, 13 Jun.( 90.240000) PPP LCP Send Configuration Request
18:34:21, 13 Jun.( 80.260000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=2848Kbps, Up Rate=448Kbps; SNR Margin Down=9.2dB, Up=20.0dB
18:34:21, 13 Jun.( 80.260000) ATM over DSL is up
18:33:40, 13 Jun.( 39.450000) WAN Auto-​sensing running.
18:32:42, 13 Jun.(172041.310000) PPP LCP Send Termination Request [User request]
17:53:14, 13 Jun.(169672.770000) WAN operating mode is ADSL
17:53:14, 13 Jun.(169672.760000) Last WAN operating mode was ADSL
17:53:12, 13 Jun.(169671.180000) PPP IPCP Receive Configuration ACK
17:53:12, 13 Jun.(169671.150000) PPP IPCP Send Configuration Request
17:53:12, 13 Jun.(169671.140000) PPP IPCP Receive Configuration NAK
17:53:12, 13 Jun.(169671.120000) PPP IPCP Send Configuration ACK
17:53:12, 13 Jun.(169671.120000) PPP IPCP Receive Configuration Request
17:53:12, 13 Jun.(169671.110000) PPP IPCP Send Configuration Request
17:53:10, 13 Jun.(169669.230000) PPPoA is up -​ VPI: 0, VCI: 38 Down Rate=1536Kbps, Up Rate=448Kbps; SNR Margin Down=15.6dB, Up=20.0dB
and tracert this
Regards
Paul
Message 5 of 5
looks like a congestion issue on the network all you can do is wait while BT Wholesale increase capacity
