dizzibits
Message 11 of 20
Re: Poor speed considering
That sounds like it could be the reason. Though without knowing what caused the noise, it leaves me a little bemused.
Is it possible using my own router caused this? For the first 4 days I ran an Asus RT-N56U.
I assume the DLM is automated, in which case, is it possible to reset it manually?
I am now back using the HH3 which has brought my upload close to sync speeds as opposed to 1xxx kbps on the Asus
john46
Message 12 of 20
unless it drops below the service minimum Openreach will not normally reset it they normally wait for it to stabilise automatically I would personally just leave every thing as it is and let it sort its self out
dizzibits
Message 13 of 20
Thanks John,
I will leave it as you say and see if there is any improvement over the week.
I could try to find out a bit more about DLM and how it works. I would be quite upset stuck using the homehub as the n56u is a much more accomplished router.
dizzibits
Message 14 of 20
This morning
Upload: 8.8 Download: 45.05 Mbps
47.76 Mbps Max Achievable Speed.
dizzibits
Message 15 of 20
Today: 37.7 down 7.77 up.
Fantastic service I'm getting 50m from the cab
sandfire
Message 16 of 20
Is that your IP Profile or some random speed test?
To hide this sig go to http://community.bt.com/t5/user/myprofilepage/tab/user-preferences and uncheck 'View signatures in posts'.
dizzibits
Message 17 of 20
BT's fttc test, the profile is the same as yesterday.
Does it matter? Surely the actual speed is more important
sandfire
Message 18 of 20
I say "random" because they all give different results, however the IP Profile is an indicator of what is actually going on - in the absence of real line stats, which BT choose to keep secret (just to make it interesting, I suppose).
sjtp
Guru
Message 19 of 20
@dizzibits  You'll probably find your real upload speed is much faster than the BT speedtester says.  Try http://mcslhr.visualware.com/myspeed/myspeed_line_capspeed.html.
dizzibits
Message 20 of 20
Quick update, thanks to all those that replied to my moaning.
The 10 day testing period is over and my line has now settled to 75~ down and 14 - 15 up
Very pleased, thanks for all the guidance
dizzi
