Trans
Message 21 of 26
Re: Poor speeds and disconnections.
Download speedachieved during the test was - 220 Kbps
 For your connection, the acceptable range of speedsis 100-500 Kbps.
 Additional Information:
 Your DSL Connection Rate :2080 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 350 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 8.3:26.12:65.71 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
Message 22 of 26
looks like it has reset again as speed on btspeedtester is 2080 which is different from router stats but the profile it at 350 which is due the the previous connection speed of 448.
you can check this and see if anything helps
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
 otherwise need to wait on mods getting back to you
Trans
Message 23 of 26
Mnay thanks to David Moon for his email 🙂
Tags (2)
Message 24 of 26
is it now fixed?
Trans
Message 25 of 26
No, but he's done some tests on my line and can see that there is a problem. He has kindly booked an engineer to come out so fingers crossed this will be sorted soon.
Message 26 of 26
great
please update after the engineer visit which I expect to be a success
