Hi guys.
I`ve been with BT Broadband for several months now and I`m a bit disappointed with my upstream speed.
Because of the limitations of my Homehub, I`ve never been able to check my SNR`s etc so I`ve replaced it temporarilly with an old Netgear I had lying around and discovered why.
The upstream SNR is set to 27db. Downstream is fine and set to 6 - 7db. TBH the downstream rate is much better than my previous provider and I realise that if it is possible to alter the upstrean SNR then it`s possible that I may lose some downstream speed but I don`t mind that at all.
Is a SNR tweak something that the Mods could look at?
Thanks.
Solved! Go to Solution.
Cheers @john46, I wasn`t aware that was the situation. With my previous provider I was getting 1024kbps up and around 6000kbps down. Is there any chance of an explanation as to why that should be? (It was Sky by the way so maybe LLU could be a factor).
I know they are two different systems at the exchange but 448kbps up seems a little meagre by todays standards. lol.
Thanks Webby. Here`s the result:-
