dancemat
Message 1 of 6
Port Forwarding HH 5 Type A
Hello Everyone,
As some of you will know from my previous post: https://community.bt.com/t5/Other-Broadband-Discussions/Stuck-on-4-7-5-1-83-8-173-1-6-HH-5A/td-p/149...
My Home Hub 5 is stuck on an older Firmware version.
Can anyone confirm if Port Forwarding works on the current latest firmware? This is for the Home Hub 5 - Type A.
I had a Home Hub 3 Type A. Also where port forwarding is broken.
I'm attempting to port forward using a static ip. Which I've read is more reliable than doing so by Device Name. However, no matter what I try, no luck. I've made sure no other firewall is getting in the way.
I'm keeping my fingers crossed this is still not an issue for HH 5 users. But the evidence in front of me is concerning...
Kind Regards,
Matthew
5 REPLIES 5
licquorice
Message 2 of 6
Re: Port Forwarding HH 5 Type A
Have you turned off UPnP?
dancemat
Message 3 of 6
Yes, I have and no difference. Smiley Sad
Is a reboot of the router required, once this is done?
Thanks for your reply. Smiley Happy
Kind Regards,
Matthew
Keith_Beddoe
Message 4 of 6
Have you read this guide?
Port forwarding problems
dancemat
Message 5 of 6
Hello Keith,
Thank you for the link to that guide. I had read it, when I had all the issues with the Home Hub 3A.
I had assigned a manual IP, in Windows. It wasn't outside of the DHCP range. Thankfully I have the latest firmware now, and all seems ok. 🙂
Kind Regards,
Matthew
Keith_Beddoe
Message 6 of 6
Excellent Smiley Happy
