PaulGB
Message 1 of 11
Port Forwarding
Help required on port forwarding with BT Smart Hub (BTHub6)
10 REPLIES 10
Message 2 of 11
Re: Port Forwarding
So do you want to know how to port forward? Explain
PaulGB
Message 3 of 11
Re: Port Forwarding
Have a web site on harddrive which I have had for a number of years port forwarding via dyn
It was easy to set up using BTHub5
Message 4 of 11
Re: Port Forwarding
Im not sure about that. Wait for someone who knows.
licquorice
Message 5 of 11
Re: Port Forwarding
The principle will be exactly the same on the HUB6, just the menu options may be different.
PaulGB
Message 6 of 11
Re: Port Forwarding
Using Synology Home Server
Cerbera
Message 7 of 11
Re: Port Forwarding
Got the same problem with my NAS. Can't get it to work! ANyone out there that can help? BT SMART HUB
phebas
Message 8 of 11
Re: Port Forwarding
I'm trying to remotely access a Foscam camera which is connected to my BTHub 6 router via aEnGenius Access point. Port forwarding is needed for the No-ip dynamic DNS service as I wish to keep in touch with the camera while on holiday. As I understand it the Access point (which has a fixed IP, as does the camera) acts as a switch and the port forwarding happens at the router end. Everything appears to be set up at both ends (both router and No-ip) but the port forwarding rule does not work. Has anyone any advice?
coder-r
Message 9 of 11
Re: Port Forwarding
I am having the same issues with port forwarding to my DVR.
Check if your ports are open on the hub through this link:
www.yougetsignal.com/tools/open-ports/
What ports are you trying to open?
I think this may be an issue with Hub.
coder-r
Message 10 of 11
Re: Port Forwarding
Found a solution.
Take static ip off the device and assign an ip through the router. Everything seems to work!
