ljm
Expert
Message 1 of 8
Port Mapping Rules
Hi,
Could someone kindly explain why my logs show pages of 'Updating/Adding/Deleting Port Mapping Rule'.  What does it mean?
7 REPLIES 7
licquorice
Message 2 of 8
Re: Port Mapping Rules
It probably means you have UPnP enabled.
Keith_Beddoe
Message 3 of 8
Something is opening incoming connections to your private network. If you look at the IP address of the device that its mapping to, you should be able to identify what application or program is doing it.
If you do not know what it is, the I would recommend that you disable UPnP on the home hub, for your own security.
ljm
Expert
Message 4 of 8
Hi Keith,
I've been looking through my Smart Hub for the UPnP which you advise me to switch off. Is it on the Advanced Settings >Firewall> Configuration page.  I found something on that page which says UPnP ON and then underneath it said Extended UPnP Security ON.  Am i on the correct page, and if so shall i change UPnP to the OFF position then, leaving the Extended UPnP Security ON?
ljm
Expert
Message 5 of 8
Please could someone answer my post, as I am not knowledgeable with these things?
Keith_Beddoe
Message 6 of 8
Turn them both off.
ljm
Expert
Message 7 of 8
Thanks Keith. I expect I should ignore the text "We recommend you keep 'Extended UPnP Security turned on to make your home network secure"?
Keith_Beddoe
Message 8 of 8
That only applies if you have UPnP enabled.
