Message 1 of 4
Port forwarding my xboxone and smart hub 6
Can someone give me the run through on how to portforward my smart hub6 and my Xbox one, also is the a rule for my to HD TVs  box ??
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Port forwarding my xboxone and smart hub 6
Hi @Toftman and thanks for posting.
Take a look at How do I set up port forwarding on my BT Hub? and let me know how you get on.
Cheers
David
Message 3 of 4
thanks, i want the actual settings (what port number to use) on my other hubs theres been preset to xbox live & other sevices, the smart hub looks to be a manuel entry, do you know what ports i use or are they automatically generated once i select the device ??
Recognised Expert
Message 4 of 4
I did a search on Google and found a page on MS that covers 'port forwarding' for the Xbox. http://support.xbox.com/en-GB/xbox-one/networking/network-ports-used-xbox-live.
What I'd say though is be careful here. In my view most of the ports listed are those that need to be allowed from inside to outside. Those will be allowed by the default firewall rules. You should not need to allow e.g., port 53, 80 from outside to inside.
