ValT
Message 1 of 6
Postcode and phone number mismatch (probably)
Hi,
I had an issue with a postcode and phone number mismatch which was first raised here:
https://community.bt.com/t5/Bills-Packages/Postcode-and-phone-number-mismatch/td-p/1736566
So I spoke to the postoffice and the incorrect postcode/address was removed from their system leaving only the correct postcode and address.
However, it appears that I'm still having a few issues with a landline/postcode mismatch? I'm apparently a silverkey holder and need to be a goldkey holder? (this doesn't make much sense to me!) Does this mean there is still an issue with how my landline is registered to the address?
Many thanks,
Val
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Postcode and phone number mismatch (probably)
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
DanielS
Moderator
Moderator
Message 3 of 6
Hi @ValT,
We can take a look into it for you. To reach us, click on my user name and then on contact the mods. It may take us a few working days to get back to you but we will.
DanielS
ValT
Message 4 of 6
Thanks for your reply. I shall do that now.
Val
JohnC2
Moderator
Moderator
Message 5 of 6
Hi @ValT Just to let you know that the records have now been updated for your phone number.
If you need any further help let me know.
Cheers
John
ValT
Message 6 of 6
That's brilliant, thank you for your help 🙂
Cheers
Val
