Hello All,
We moved in to our new house on Thursday, prearranged everything with BT, our account was live, the modem was delivered etc. However I realized that the previous tenants (probably) took the power supply of the wall mounted optical network box.
Not to worry, I tried the BT modem's power supply as I had a spare (electronic engineers now demand my head, I know) and it worked, perfect fit, lights coming up, Power, PON, LOS, TEL, PORT1 turns green after a while.
Still no connection, modem is having the B red flashing with the cylon line continous orange. According to BT all is good on their end, they will send an engineer to check. So now I'll wait for the engineer but in the meantime, does anybody have the specification for the power supply of this ONB?
Mine looks exactly like this:
https://cdn.recombu.com/media/digital/news/legacy/M11039/1351515986_w670_h549.jpg
thanks!
Solved! Go to Solution.
Engineer come out, he installed the proper power supply and the battery pack. It wasn't the power supply though, openreach failed to activate something? Anyway, all is sorted now, I'll post the type of the power supply when I got home just in case somebody will need it in the future.
Hi @Shadoan,
It's good to see everything is sorted now and the engineer was able to get it fixed.
It would be good of you to post that. If you could post a pic of it too it may help others
DanielS
