Message 1 of 2
Powerline Adapter
I'm using a powerline adapter for my HTPC upstairs which the router is downstairs and all my wired connection devices is set to Always use this IP address in the router page but wireless connection devices is set to No, but what about the HTPC that is connected to the powerline adapter, should I set it to Yes or No?
1 REPLY 1
Message 2 of 2
Re: Powerline Adapter
It's entirely your choice, it doesn't matter either way. However, if you wish to stick with your scheme of fixed for wired connectiions and DHCP for wireless, then set it to 'yes'. Think of the powerline adaptors as just a part of the ethernet lead.
